Interested in getting others’ thoughts on this. I have both a Garmin Fenix 6S sapphire watch and a Garmin Edge 830 bike computer. My tendency is to use both to record rides, both road and MTB. Initially I used only the 830 but would sometimes find that the watch would yell at me for “high heart rate” if it wasn’t actually recording an activity, so I started recording rides with it, too.
On road rides (meaning rides with fewer overhead impediments to the GPS satellites) I find the two devices are remarkably consistent – like nearly identical total mileage readings even after long rides. However, on MTB rides, which I do in pretty thick area forests, the mileage disparity is much larger – it usually works out to around 2% (roughly 0.2 miles on a ~10-mile ride), and the Fenix always displays the longer distance. I should note that the software/maps in each are fully up to date and I always use the “GPS + Galileo” setting for both devices.
I find this interesting. I can only attribute the distance disparity to what I guess are GPS signal strength differences between the devices. Which do you think is closer to the truth? Is one unit known to have a better receiver than the other when under thick tree canopies? Logic might suggest the larger distance number is more accurate (the longer distance implying fewer dropouts between datapoints – or something?) but maybe that’s just wishful thinking. If I look at a completed ride’s map traces on either Garmin Connect or Strava, they look identical between the two devices.
This does not keep me up at night; I just find it curious. Would love to hear others’ ideas or knowledge about the relative accuracy of these gadgets. Thanks in advance!
