Hello ’ every one, I need suggestion how to use TR with minimal devices.
Do you know if TR will work properly only using HRstrioe and cadence sensor?
Next month , I am going to work abroad and the only way to continue for training would be to use a spin bike…I am going to have HR stripe and cadence sensor, anything more…
Thank you on advance for your tips
put a speed sensor on wheel. I used some dual lock velcro and put a garmin speed sensor on my old spin bike. It worked great, I also had a cadence sensor on cranks and used Garmin rally spd pedals; The newer sensor only works like i have it, the older ones will work on side of disk. then u just have to calibrate. https://screenrec.com/share/RZXAtpoOxP
TR supports RPE if you don’t have power. Or perhaps virtual power?
FWIW I used HR zones before power. It requires some understanding of how to use HR zones for training, but has been very effective for my training before and after buying a power meter.
