TR + Power meter + Garmin
Hi All,
Currently I have Assioma MX2 dual power pedals.
I run on manual rollers (Inside Ride eMotion).
I thus control power myself, and have my pedals and HRM connected to TR for power / cadence / hr stats.
I’d like to be able to see my pedaling dynamics as well through Garmin connect… Currently TR does not seem to push this info to Strava / Garmin.
Am I doing something wrong?
Otherwise, is it possible to « double record » my workout on my Garmin Edge for pedaling dynamics but not have workouts double counted? I suspect this may create a workout for TR and a clone workout for Garmin which will screw the stats?
Cheers and thanks for your help !
I dual record my rides. TR has no problem recognizing the duplicate workout, Garmin shows both. I usually just delete the TR workout on Garmin Connect.
Cool! Ill try it next ride. Are you on Strava as well?
You might not even need to record the activity on your Garmin. On my Wahoo, I can connect to a power meter and see the live data without recording it.
If you want to save that data, then dual record it is!
I dual record too.
TrainerRoad copes with duplicates fine and doesnt show the garmin workout.
You will need to removed the duplicate from Garmin connect and Strava though.
