TrainerRoad with multiple iOS devices
Is there any technical reason for not using multiple Apple devices (iPhone, IPad) with the TrainerRoad? Not simultaneously, but every other day, for example.
Will there be conflicts or is it running just fine?
Nope. As long as your other device is not also trying to connect to your trainer, power meter, etc. at the same time.
Only issue I’ve experienced is my favourites not syncing
What about trainer spin down/calibration data? I’ve often wondered this as I often switch between a MacBook, iPad or iPhone. My MacBook is primary source and one I perform spin down tests with usually. Does this get stored back in the Kickr?
Calibration is stored in the trainer, so no issue there either.
Cheers Chad, thought it must be.
