It looks like Trainingpeaks changed their Export Workout File to only be ‘FIT’ and ‘ZWO’ and no longer contains ‘ERG’ or ‘MRC’. Is there way/workaround to get the FIT or ZWO files to transfer over as easily as the ERG or MRC files did? It was super easy before so I’m hoping it’s just a short term issue.
Are you using Mac or Windows?
Drag and drop doesnt seem to be working in Windows unless I am really doing this wrong.
EDIT: Nevermind it was WHERE i was trying to drop it. If you drop on the list of workouts it works.
Wow WTF have I been doing with my life trying to rebuild out 16wk plans…
One question: is it a HR-based workout, not power? I remember one time running into an issue where it was HR-based and I couldn’t download it properly.
Depending on the number of workouts you are looking to convert you can likely just whip it up in under 2-5min per workout.
Until I found the download trick I literally built out 80+ workouts in the span of two days in some spare time. Especially because workouts don’t change their fundamental form all that much, once you have a few templates to build from it goes very quickly.
