Got my new checkpoint and put it on my kickr core. I got the cassette worked out but still was noticing a rubbing noise. Turns out that the the “thru axle conversion piece” does not fit into the drop out area and instead of seating rubs against the carbon… anyone else have a checkpoint and kickr ? Very frustrating
Yeah. I took a Dremel and 1/2" drill bit to the Kickr handle. It took a bit, but I hollowed it out for the dropout adjuster to fit on there. It was fine after that. The handle wasn’t structurally compromised, and they can be purchased as a replacement part pretty cheap.
Yes, I have a 2015 Domane with post mounted disc brakes. Bought a Kickr 2017 in October of 2017, and the thru-axle adapter wasn’t flush. Here are a few pics I sent Wahoo:
and
as you can see the thru-axle adapter wasn’t flush. I worked with Wahoo and a month later they sent me a new adapter that was machined down a bit to allow the adapter to sit flush without hitting the brake post.
Give Wahoo support a call. Hope that helps.
Super helpful. Thanks
