Pinkbike did a field test on these bikes among many others. I liked their videos, but it made me want all the bikes.
You may also consider getting a dropper for your current bike to see if that helps with your descending. There is a learning curve, or familiarization period, and some seem to pick up on dropper use quicker than others.
Do people use protection film for the flexible seat stays on the SC? I am going to get the SC and wondering if the wrapping of the flexible seat stays will stiffen up the seat stays, leading to greater stress load at the ends of the seat stays that connect to the seat tube and the rear dropouts. If so, then would the greater stress at these locations exceed design limits? I suppose that nobody may know the answer to these questions.
I did talk to Trek and they said that they themselves sell RideWrap and using it shouldn’t void the warranty.
I was thinking of Invishield, but I think I might just go with RW.
Thinking back to beam theory from a college course many eons ago, I suppose that cutting slits in the wrap at the lower part of the seat stays where tension would be the greatest would mitigate any stiffening effects of the wrap…
I’ve never used a wrap but I imagine they aren’t super stiff. Like a beefed up sticker basically. I highly doubt they would significantly add to the stresses on the stays. I mean the bike is designed to take drops of a couple feet and probably sees wayy higher stress if you accidentally lock out the shock on a decent hit than if you put a sticker on the stays. Especially if Trek says they sell a similar product than I’m almost certain it would be fine.
The Trek is only 60mm rear travel. I saw a comparison of bike weights and the Supercaliber was middle of the pack on weight compared to other high end XC bikes. Epic, Scalpel, etc… If you’re only gonna give me 60mm of travel at least give me a competitively light frame.
