TSS estimation without power
Did a7hr outside workout and power meter died at 30min in. So only heart rate. How do I get the system to ignore the power data and just use HR?
I’m not sure there is a way to discard Power Data once it is part of the file from our side.
I suggest an email to support@trainerroad.com for help with this, since that is often faster than waiting for a tech to find it here.
Worst come to worst, if the file is in strava, you could download the origonal from strava, remove the power data using https://www.fitfiletools.com/#/stripper#view and re-upload to strava
IF TR can’t help, e.t.c
@mcneese.chad and @WombleHunter nailed it here for you – shoot an email to support@trainerroad.com or use the FIT File Tools Field Stripper if you feel comfortable enough doing it yourself.
Additionally, this article will help if you haven’t already enabled HR-based TSS estimation on TR.
Let me know if you need a hand with anything else!
Ended up using GOTOES to strip out the partial power data so the TR treat it as a no power workout.
