Any opinions on the following welcome… I know I’m not very low but have IM Wales in 4 weeks which is very hilly. I know I need to get a proper fit but I’ve struggled to find a decent tri fit near home.
Thanks for such quick replies, no issues really, just lack of confidence in my own fitting abilities.
I’ve only had a tt bike for about 4 months and so it’s still something that I am adapting to. I’ll try raising the saddle a bit
Yup, looks like a decent fit, and more importantly, if you aren’t having problems… do NOT make changes. As above, 4 weeks is too late to make big changes. And unless you had comfort issues, there is no need to risk breaking something that is working.
I think you should do the event and use it as a data point for potential changes afterwards.
obviously not relevant if you aren’t making any changes and a very very minor detail, but try to get the phone to 90 degrees to the bike and level - all your measurements will be slightly off if not - I think that BikeFastFit has an alignment page.
After my bike fit, I found out that switching to a shorter crank (165 mm instead of stock 172.5 mm) was better for me due to tight hamstrings. On the Retul setup, I felt much more powerful with a shorter crank. Downside is that my 172.5 mm Stages L is now rendered unusable
For you, it might be too late to see if a different crank length works better - I think it’s best you wait till after your race to make a change like this. Plus, I don’t race, so I am not too bothered by the loss of sprint power due to a shorter crank arm.
I’m going to join the chorus of “don’t change anything now”…but I would ask if you are on your soft tissue, and could shift forward on that saddle. It’s tt saddle I assume?
It’s an ISM TT saddle, think you’re right in this image I am sat a little further back on soft tissue, I had a long ride on Sunday and havent quite recovered from it yet Haha.
Do you think fit wise I’d be better further forward then? Dont think theres massive room on the rails to go further forward…
Hard to say…but the foundation of the set up should be built around the best seat position.
Don’t change it now, but it may be as simple as shifting the seat back slightly. This would mean your body position isn’t changed but you are getting on the saddle effectively.
The idea here is that he’s not perched on the saddle properly now. If he shifts the seat back to correct this, he won’t need to move his body position at all, so the hip angle will be unaffected.
