Tyres that fit on Mavic Cosmic Pro Carbon UST Tubeless
Hi Trainer Roaders,
Hoping for some helpful advice on my tyre and wheel combo. I roll on the Mavic Cosmic Pro Carbon UST Tubeless Rim Brake wheel-set. A fast a reliable wheel-set however like many many others I have experienced removing and reinstalling the tyres especially tough when repairing a roadside puncture finding it almost impossible resulting in several taxi rides home. This is something I have never had issues with whilst using other wheels in the past.
The tyre combos I have tried on the wheel-set previously are the Continental 5000s 28mm, Vittoria Corsa G2.0 28mm and the Mavic Yksium Pro UST II 25mm - all of which have been very difficult to seat onto the wheels.
I am looking for a suggestions on a fast training tyre that can be easily fitted with an inner tube onto this wheel-set that doesn’t require an oven/ hair dryer, large tools you cannot fit into a bike bag or the strength of Thor!
So any recommendations would be amazing.
Thanks
Richard
I haven’t got your wheelset but I would give the hutchinson fusion 5 performance tyres a try.
They are the loosest fit tubeless tyres I have tried - and they performed pretty well. They arn’t too different fit wise to the mavic UST (made by hutchinson) tyres though.
Thanks for the recommendation Kev I’ll look into the fusion 5’s.
Despite the wheels being tubeless ready I’ve been going for the tyre inner tube combo as tubeless on the road has let me down a couple of times. If you can think of any other non tubeless tyres that may suit let me know.
Thanks
Ah sorry I misunderstood, thought the inner tube requirement as just for emergencies on the road :+1:
Have you looked at how much rim tape you have on the rim? Tires are SUPPOSED to be tight on a tubeless rim. If you dont want to run them tubeless, you might try unwrapping some of the tape if possible.
Hey Earena,
Thanks for this. I’ve actually taken out any rim tape. So one step closer to cracking this!
Many thanks
These wheels are the worst IMO. I have a set that I had built last year and I’ve just stuck with the Schwalbe Pro One TL tyres. I don’t use the bike that they’re on anymore thankfully so don’t need to stress about getting a puncture and needing to get home.
One tip I do have though is get the Crankbrothers tyre lever and take two others with you when you go out. It’s the only way I could get the tyre on and off. I have to use the standard levers to hook the bead then use the Crankbrothers lever to actually sweep it around the rim to get it out. The Crankbrothers lever has a hook thing to help you get the tyre back on the rim too. Expect to sweat still but it’s the only think I could rely on.
I can’t wait to see the back of those wheels and will never use/recommend those rims again.
Edit: I once took the wheel to my LBS when my boyfriend was away (I’m not one to generally rely on male help when it comes to bikes as it is but these wheels were the exception!) and they sent the wheel out of true trying to prise the tyre on to the rim!
Hi Richard
Did you find a solution to the tyres. I cannot get mine off for the life of me. I have to take them into a bike shop. Its a joke. I need some tyres to run with inner tubes that I can get off road side. Did you find a solution?
Thanks
Kate
I have had similar issues with my Mavic Pro Carbon USTs.
I tried to mount GP 5000 TL but there was absolutely no chance to get these on the rim. Tried all tricks that I could find on the internet as these rims seem to be known for complications.
Now I am running Schwalbe Pro One TLE, which were also close to not mountable, but with all the skills and tools that i acquired over time, I managed to get them on. However, I will never ever be able to get these off and back on at the side of the road with two levers. Im just praying that i dont get a puncture.
Does anybody know if its easier to mount non tubeless tyres onto the Mavics. That’s my secret hope. I am not a fan of tubeless anyway. It let me down twice already.
Hi there!
I have been facing the same problem. I am running vitoria tires which I will ditch, they are very difficult to mount and dismount. Besides the Hutchinson any other suggestion?. The Hutchinson tires are not available currently.
Cheers
After killing both of my thumbs, I ordered the Kool Stop Tire Bead Jack, I was sceptical but was able to get the Gp5000 TL to fit, so satisfying, they are so hard to fit on the mavic cosmic pro UST but when they do, you can pop them in without pressured air, because I hey are so tight! Also they hold air without sealant, so hopefully double protection with sealant!
