I’ve started to see poor shifting with my front derailleur (Ultegra Di2 12-speed R8150) shifting from the small to big ring. Not all the time, but enough to start bugging me. I can generally get it to shift, by dropping a gear at the back and then shifting front derailleur again.
Everything had worked fine for a year, and limits should be set up correctly. Problem only started the last month or so.
Any ideas on what to look at first? Or should I treat it as if I’m starting setup from scratch?
I’m on the 11sp 8050 so went into the shop for the recall inspection. The shop somehow managed to not get the crank all the way back in when replacing, and it mostly felt fine, but the small alignment difference caused issues until I realised what had happened.
Hello! I am having exactly the same problem on a Shimano Ultra R8150. Right after turning on the shifting system pushing the bottom of the rear derellieur once, the shifting of the front derelliueur works just fine (I can shift up and down multiple times without problems). However, in the middle of a ride, it can happen that I can not shift anymore from the small to the big chainring (from big to small always works well). I usually get it to work after many times. I did a firmware update of front and rear derailleur but it did not solve the problem. I use waxed chains and change then every 300km, the problem does not seem related to them. Do you think it may be a misalignment of the skid plate? Anyone who solved the problem?
any chance the cage got dinged and its bent a hair? Ive had that happen and your symptoms sound identical. If not, id just start fresh. move the adjuster to 0 and follow the startup guide from the app. If that doesnt work, its time for a trip to the shop
Finally got the chance to take a look yesterday, took the derailleur off and started setup from scratch again. Shifting fine in the stand, but still intermittent issues during this mornings ride. Will probably live with it until it bugs me enough to take to the bike shop.
Hi - did you solve this?
I have Ultegra 12sp. 3500km old and exactly the same issue. The shifting ramps on the big ring look like theyre worn. Ive borrowed a lightly used second chainring from the mechanics bikes and its much better. 3500km ol and chain ring worn out seems unacceptable
