So for the last few ramp tests I have underperformed on what I felt should have been achievable. I was performing my workouts at 235 watts and have dropped to 222 after this last ramp test. I weigh around 68 kilograms. I have nailed all but one workout last training block (sweet spot base 1) and felt pretty good doing them (relatively). The last ramp test I performed last go around yielded similar, yet worse results. I went from a 240 watt FTP to 215 (still had pretty successful workouts before that catastrophic drop as well). Afterwards I just bumped my FTP up incrementally after a workout until they felt difficult again.
I do feel that my life has been more or less consistent with stress. Sleep has been a struggle as I have a 2 month old, however it has been consistent (albeit consistently low). Diet has also been consistent.
I went into the test with a fairly positive attitude and my legs felt like within 20 seconds went from “okay” to 40 rpms, then to failure.
My question is with the information that I currently have should I continue with my old 235 FTP and chalk this test up to some unknown externality…or accept my fate with a lowered FTP despite really nailing all my workouts and power targets prior to the test?
If I should disregard the test, what do you think is causing me to underperform during my ramp tests? I am really at a loss here.
Thank you guys for all that you do! Love the podcast, 5 stars!
I’m like the president of underperforming on ramp tests despite nailing difficult workouts. Lol
I did short power build HV with a 290w ftp and completed some difficult workouts and I just couldn’t mentally bring myself past the 260w point on a test last week. You have to be somewhat flexible with thinking and realize the test isn’t everything, especially if the training evidence suggests you can complete workouts. I upped mine to 295 and have been successful so far in CX specialty HV.
My uneducated guess is that Sweet Spot Base 1 just doesn’t provide enough training stress. I have noticed this myself after completing SSB1 - SSB2 - Build - Speciality, that when I restart the process, it just isn’t enough training stress. I’ve noticed that intervals.icu seems to think so also, as the eFTP is slowly but constantly decreasing as the weeks in SSB1 goes by.
For what? SSB is building your aerobic base. Depending on where you are in your training journey that may not increase your threshold, but it will do what it says on the tin.
eFTP is only as accurate as the max efforts you feed it. If you’re doing SSB1, you’re doing a lot of sub-threshold work, and not a lot of anything else. I remember @davidtinker saying there’s some algorithmic degrading of the value the longer you ride without max efforts, and you’re not doing max efforts on SSB1.
Don’t think of it as underperforming. If you’re going to your limit during the test, you’re not underperforming.
The ramp test assumes some things about you as a rider. They’re general assumptions that work well enough for most people, but they don’t work for everybody. If your threshold power and max aerobic power have a different relationship than the one the ramp test assumes, you’re going to get an inaccurate threshold estimate when you do a ramp test.
You’ve got a couple of these under your belt now, so you’ve got options:
Do your own math. The ramp assumes your threshold is 75% of the highest 1-minute power during the test. Maybe your actual relationship is more like 77% or 80%. Go back and look at the ramps you’ve done, and compare the max 1-minute power to the threshold you ended up using. If it’s consistent, maybe you keep using the ramp test, but change the math.
Use a different test. There are 8-minute and 20-minute protocols in the catalog, and there’s a pretty popular alternative from Kolie Moore. The longer your test, the harder it is to pace, and the more accurate it’ll be if you pace it well.
From the level you were training at, at the height of build/specialty phase. The training stress is drastically reduced when you revert back to SSB1. So at least to me, it makes sense that it will lead to a loss of fitness?
From what I read about eFTP on intervals.icu it decays if it estimates that your current training is not sufficient to keep the level of fitness.
That is correct. However the decay is fairly arbitrary. It doesn’t seem right to keep the same eFTP if you are reducing training load but how much to decay is a big question. The algorithm needs a long enough max effort every now and then. You can click the “eFTP” number on a ride and it will tell you the eFTP for that particular ride. So if you do a proper max effort on good legs and get a lower number then thats it … but the software doesn’t know that.
You can add a calendar entry with category “Set eFTP” reset it e.g. after an injury break or whatever when you know you have lost a lot of fitness and want to see it going up again.
Maybe try the 8-min FTP test? I know it’s not the same “measuring stick” but it could get closer to the FTP you use as a base for the workouts. I personally get better results on the 8-min test vs ramp test, nothing major, around 2-3% difference.
My bit of encouragement here is that the sleep does improve from about 6 months onwards. The first 6 months are a test of your character to say the least - especially if you are trying to juggle a newborn and structured training on the same plate. When you are staring down the barrel of 3-5 hours broken sleep a night, you start thinking how on earth am I going to get on the bike today?! I feel you mate. I really do! I have been there and have had some really sub-optimal performances on the bike because of the lack of sleep. The good news is that when they start sleeping through the night at around 12 months old you see the light again!
Just stumbled upon this (version) of this thread. Interested that you have more accuracy with the Zwift Ramp. Is that the “Ramp Test” or the “Ramp Test Lite”
I’ve been self selecting FTP, and then confirming, but may give the zwift version a go. I can’t get over my mental block on the TR version at this stage.
Just the regular ramp test. Zwift’s jumps by 20 watts each step whereas TR’s increases at 6% so at 200ish watt FTP that difference definitely helped me get a higher average 1 minute power.
However, I have recently learned what sweet spot and ftp workouts should actually feel like. And have now moved onto the Kolie Moore FTP and TTE test. In hindsight, I don’t think either ramp test were accurate for me
Ramp tests aren’t really indicative of FTP for many people. Also, despite the KM protocol being longer it is much more comfortable. It also teaches you what threshold really feels like.
I’m 3 weeks into training in resistance mode focusing on a custom sweet spot plan including some teetering into threshold and trying to find just that spot where my breathing changes and legs feel different. I can definitely say I’m much more confident in knowing that delineation. Lastly, the test makes you know the work you’re capable of because it’s a TTE. I’m excited to take my next test on Saturday if I can get the part to fix my bike after breaking it this morning…
I did an 8 minute ftp test (the one programmed into Wahoo Bolt where you warm up, then do 2 x’s 8 min efforts, with a rest between them, average the power and multiply by .9). I had even run into some friends and did a sprint to catch up to them during the rest between sets, and tested at 265. My first 8 minute, held 304, second one 284. Probably could have done better if I wasn’t an idiot. Trained for 8 weeks set at 265, and finished every single workout without fail. This week, I did a ramp test indoors on my wahoo kickr. Scored 213. Solution? Sold the kickr last night, bumped up Ftp to 270 watts based on gut feeling and continue doing my workouts outdoors as usual. Not a problem. Ramp test and riding indoors just doesn’t work for me.
