Hey everyone,
Recently my Garmin 520 decided to crap out - utterly dead and utterly out of warranty.
I was pretty disappointed as I’ve now had a number of Garmin devices that have died prematurely, despite having fairly easy lives.
I’m looking to replace it with a wahoo elemnt bolt, however I’m running vector pedals (which I’ve also had nothing but trouble with). Will they work properly with the wahoo? I can see they’re not listed as compatible and apparently a Garmin firmware update hampered communication?
Any experience of this would be gratefully received.
I run two sets of Garmin V3s, different bikes, and a Wahoo ELMNT Bolt and never had a single problem no drops of any type, indoor or outdoor.
Garmin pedals w/Wahoo head unit
*Don’t cross the streams! It would be bad"
Seriously though, you should be fine.
You got your chocolate in my peanut butter.
No, you got your peanut butter on my chocolate.
I run vector3 with Elemnt Bolt, zero issues with interplay both Ant+ and BLE in about 18 months of use.
And now I believe the Wahoo app even supports some of the advanced cycling dynamics measurements.
I have V3s and a Wahoo Elemnt, but I still use my garmin 920 watch to capture the ride alongside the element as my main display. This is because the garmin 920 captures all the pedal dynamics and L/R balance info and correctly displays this in Garmin connect.
I found that data going through the elemnt, as a fit file, when imported to Garmin connect lost all of the data underneath the graphs. Wahoo blame garmin… etc…
The Element is capturing the L/R balance because I see it in the graphs and in the data at the end of a ride. (I don’t think it captures pedal offset). But I have been unable to get the data out reliably, or display it on Garmin connect apart from as a graph with no summary figures below.
If anyone has been able to solve that I would appreciate knowing how, it because it annoys me a bit.
Cheers
Cheers everyone. Managed to get my hands on a wahoo bolt to test them out with. They seemed to pair alright, but I noticed a few drop outs on the few rides I used it that were out of the ordinary. This may have been totally circumstantial… but I decided to go with the 520 plus as it has cycling dynamics (who doesn’t love data that’s next to meaningless?) and I got it with a pretty good discount.
