Virtual Power vs. Wahoo RPM Cadence
Does Virtual Power mode trump a Cadence monitor? After installing new Wahoo Cadence and Speed monitors with a bike sitting on a CycleOpd Fluid2. Wahoo RPM Cadence pairs, then stops when I start to pedal. The Speed sensor works, but Cadence blinks and then drops, or is not listed. When TR stops, the Cadence sensor picks up again.
Virtual Power and Cadence are not really linked in any way that I am aware. VP uses speed data only, and is not looking at cadence at all.
It is probably best for you to contact support@trainerroad.com to see if they can find anything in the logs or have other suggestions for you.
