For me, I’ve found that 3-minute VO2Max intervals at 120% are most effective at maxing out my respiration rate (i.e. oxygen uptake, CO2 discharge). They also suck the most. Once I can hit 7 x 3/3 (7 3-minute intervals with 3 minutes of recovery) then it is time for an FTP test.
When not having done VO2Max intervals in a while, then progressing from 30/30, to 1/1, etc up to 3/3 works well. SSB2-MV has an aggressive progression of Taylor -2, Bluebell, Mills, Spencer +2.
Totally agree. After several years of battling with longer V02 (3 mins and over) on trainer and 'how hard should i go? What power etc? I have now found that best protocol for me is to use my bike without a power meter (radical I know!), wear HR strap, go to a local hill that takes about 3-3.5 mins flat out (but can start on long flat before the hill to extend to longer intervals). Just go hard and hold on as much as possible until I get to the top of the hill. Keep cadence high, HR usually hits 90% max after about 75-90secs and stays well above that until top of the hill. Ignore power, just go hard and keep going! Then roll back down hill, ride easy for few mins…and repeat!
Have you tried longer VO2max intervals? I used to do 10 x 3 minute intervals, but compared to 4-7 minute ones they seemed to place more emphasis on anaerobic capacity.
As for untruths, I would say that exhibit 1 is the apparent belief of many here that training VO2max is somehow complicated, or conversely, that making it complicated is somehow better. But, that’s how stuff gets sold, because no one is going to pay for what is already common knowledge.
@old_but_not_dead_yet, yes, I’ve tried longer intervals in the context provided by Sustained Power Build. There are a couple of workout in the 5-minute @ 108% range and 10-minute threshold @ 105%. Nothing beyond that, though.
I thought I heard on the podcast that anaerobic contributions were essentially spent after 75 seconds, so the rest of the intervals should be almost exclusively aerobic. I guess that supports doing even longer intervals, though, from an overall percent of time in aerobic.
I think this is an area I that I have an issue with in regards to TR plans, yes you have to put the workouts into the context of the overall plan but if you are targeting VO2max you shouldn’t be even considering a percentage of FTP, keeping it simple you should be completing the intervals at the highest ave power you can. Go hard or go home!
Good that you are trying that stuff out, but…as has been somewhat sussed out, power is but a very general target (because VO2max isn’t about training power). Those lower ranges can elicit adaptations but they won’t be awesome; remember, with VO2max intervals you’re going after central adaptations (i.e. the heart).
A good starting point for variety is the classic Coogan ‘no-go’ power zone chart: 106-120% and 3-8min.
It depends on your anaerobic capacity. 75s is, again, like 120%, a general pop. guideline. Just look at the Ramp Test and all the wonky results that spews out for anaerobically under/over-developed riders.
For a platform like TR et al, all these generalities will serve most of the people most of the time and bring about standard bell curve results. It’s up to you to figure out your own capabilities to maximize your efforts and results.
Some of the most effective v02 sessions I’ve ever done was when I got a coach that prescribed them as little more than “jam it up a climb for 3-5 minutes and then spin down for equal time until you get 12-20min of work,” so I ended up just giving it all I had that day.
I think there’s a tendency to view specific power targets as a pass/fail metric to achieve x adaptations, but I found out I was leaving a bunch on the table that way.
I have two VO2max eras – pre- and post-power meter.
I might posit that my pre-PM sessions (5x5min by HR; rarely completed that 5th interval) were a lot harder and a lot more productive than those done by PM. My 5min pre-PM power (measured once I got a PM) has never been matched/beat by PM-era training.
If you’re gasping, you’re doing it right. If you can curse out loud, you need to go harder.
Because power is a good carrot. It’s easy to let up just when it starts to matter/hurt, especially if you start out way too hard the way most people do.
I once knew a guy who said he had never completed Friel’s 1-2-3-4-5-5-4-3-2-1 minute ladder workout. I could never understand that, until we did it together one time. He attacked the first couple of intervals as if he were attempting to set a PB, then blew up. The only reason he finished the whole workout that time is because we were doing them on a short-ish loop, and I kept going, lapping him a couple of times in the process.
While it’s true that one’s VO2max relies on a combination of factors, including capillary and mitochondrial density and which can be improved from sub threshold training (base phase), it also largely relies on cardiac output.
Are you suggesting that a decently trained athlete can improve cardiac output riding entirely at or below threshold?
I do/have. My first 6mos with TR is the only time I’ve done power guided VO2 intervals. It’s been HR and breathing otherwise. But that’s not to say power should be completely ignored.
That would depend on just how “decently trained” they actually are. Clearly, though, forcing the heart to pump hard for hours and hours on end is a potent stimulus for adaptation - ultimately, in fact, maladaptation, if you consider hypertensive patients or animal models of pacing-induced cardiac failure.
Again, the notion that the heart only adapts to exercise close to VO2max is clearly incorrect.
