My girlfriend has just started to use the wahoo bike and I reverted back to the original QR. Well tonight I snapped it off and I’ve some how lost it in my garage…
I’m assuming I should replace it when a steel one as it’s more durable? Also, does anyone know what length I need and diameter please?
Thank you
Assuming that you are talking about either or both of the red and yellow parts (not the orange arrow one), it looks like a standard QR lever assembly.
One option is to slip the black collar off the bike and take it to a local bike shop. They should have some on hand for a dry fit test and/or measurement.
The inner threaded “screw” portion is almost always steel unless noted otherwise. The one you broke is like steel as well as the outer nut is a steel insert with plastic over-molded. Some of the older style QR’s have steel lever two (red section) so that could be worthwhile.
And as a guess, if this broke from heavy tightening force to prevent the seatpost from slipping down (seems a common issue with these bikes), I’d recommend using carbon fiber paste to improve grip without requiring large clamp forces.
Yes that’s it, the yellow one. I broke the silver threaded part. That’s one thing I haven’t tried is carbon fibre paste. I have previously used a nut and bolt because I never changed it
Thank you
Had the same problem. and more of an issue as both me and my wife use the Kickr 1-2 times a week. not a problem of slip for her but as i am 85KGS after 15 minutes could slip 1cm and broke 1 lever. Wahoo sent free seat post as solution?? My solution has been to buy 0.3mm THICK SHIM WASHERS Size: M28 x 40mm from ebay. i then took seat post to a local metal dealer (after calling them) and they sold me a aluminium tube 1metre offcut for £20. My neighbour then cut to the correct length (one for me and one for my wife) using a lathe but i am sure if i had asked metal dealer to do they would have. not i just remove seat put tube over and one washer on bottom and tighten just enough to reduce seat movement. i can feel silghtly less flex in sit post if sitting up and spinning legs but when normal cycling on Kickr no problem and zero chance of slip.
