Does anyone have a trick to opening the wahoo rpm cadence sensor case. I have tried coins, fat screw drivers, break disc ( The sram disc almost matches the curve of the plastic case)
I have just about destroyed the plastic shell and have only change the battery 3 times!
I suspect something like this designed for taking apart phones/tablets would do the trick, but I’m too impatient to buy tools for a specific job and end up just hammering away at it with random things from my toolbox until it’s open.
Mine is full of nicks and marks from my attempts at getting it open. Used a screwdriver and a coin today and found that the rubber seal is split - possibly from using the screwdriver
Mine was mangled so much, I used vice grips to gently hold the bottom half. Squeezed it and voila. Mine is so mangled , this will be the only way to keep it alive. I have only changed the battery now twice and I feel I’m generally good with tools. grrr…
I sometimes use the back end of a fork or spoon, I have a few that fit the profile well
I also have found certain specific coins or tokens work well. I have a token from some game place that fits perfectly and it’s my go to and lives on my desk just for battery swaps
Used a flat head screwdriver and mangled the case along with tearing the o-ring on my cadence sensor, luckily it just sits on my dedicated trainer bike so no worries there.
Learned my lesson and used a quarter on my speed sensor (outdoor bike) which worked much better…still not perfect but it didn’t destroy it.
I guess the trick is try to use something that has the most surface area covered. Really needs to be less force holding these things together or stronger plastic though.
I got rid of mine and replaced it with a Garmin, which has an actual battery cover. On the Wahoo, I also had issues with the battery making contact and had to put padding behind it. Poor design all around.
i use a 2p piece and my rubber seal has split, i have emailed wahoo support to find a replacement seal, but looking at the 2p piece and wrapping the broken seal around the coin its a diameter match. so i fofund out the diammeter ofa 2p and bingo a pack of hteree seals from ebay free delivery 26mm x1mm is on order free delivery. £1.46 Sold by sealwithselo
