Wattbike Atom ERG mode
Is there still an issue with the Wattbike Atom & not being able to run outside of ERG mode?
This article seems to suggest it is still an issue: https://support.wattbike.com/hc/en-gb/articles/360006052240-How-to-connect-to-TrainerRoad
How are people\users overcoming this issue with short sharp intervals where you would traditionally drop out of erg mode to undertake this?
Is this a Trainerroad issue or a wattbike firmware issue? I note in other platforms you can drop in &out of erg mode so my presumption is its a TR issue? (Happy to be corrected on this).
Did I also imagine it or did someone say in the podcast they have a Atom being sent over to use as a test machine?
Bump for the evening\day crew who might be able to help.
Based on my latest records, “Wattbike has not implemented resistance mode for the Atom, and has not decided if they will do so yet.”
That being said, they make have released a firmware update that we are unaware of, which could allow for this increased functionality with Wattbike. May I ask what platforms allow you drop in/out of ERG/Resistance mode?
Cheers for picking this up & replying @Bryce
When I say resistance mode I mean using the gears to adjust resistance. The Atom can run in 11 or 22 gear mode.
Zwift will let you turn erg on / off mid ride or interval
The wattbike app will let you turn erg mode on or off - this is done by a top of shifter button and would be great if TR could get this to work.
For example doing over/unders or short intervals, one click will take me to erg and then the next click drops me back into the gear I was last using… it’s a neat little intuitive function.
When using the wattbike hub the gear shifters will also increase or decrease watt output by 5 in erg mode, so 1 click will take you from 220 to 225 or 215 dependent upon which shifter you hit for on the fly micro changes.
@Bryce was there a follow up on if this will get fixed?
Sweet spot solidly in erg mode is currently killing me and would be good to have the option to do it via gearing/resistance mode.
Hey Hoppy,
Sorry for the delayed response here. I chatted with our App Product Developer Pete Morris and he has created an issue for this :+1:.
At the moment, we’re in the throes of a total app redesign, so this is not currently a high priority issue, but as we complete our current projects, resources will free up and we will be able to work on device layer improvements like this.
Cheers!
