I will be basically using it exclusively for TrainerRoad ERG mode workouts. Here are my priorities (in order):
Cost. Probably the biggest one, looking to keep it under $1k for sure. Ideally something around the $700 range, preferably cheaper. As a student I don’t have the money for the top of the line newest stuff. I want a warranty on it for sure, so buying used is out of the picture.
Accuracy. ±2% probably, ideally better. I want measurements I can trust as much as a power meter. I have a quarq on my bike right now.
How well it works in ERG. Want to do those microburst workouts effectively for example.
Noise. I live in an apartment, and do my workouts at night. Want something quiet for sure.
I am fine getting a refurbished trainer, or an older model. I have 10 speed, so trainers with a cassette are going to be useless for me (since they typically include 11 speed). Any recommendations? I was looking at some of the older models like the original drivo on amazon.
3rd support for H2 trainer at that price. Nothing in the regular “mid-level” price point can touch it for capability or reliability. I have see too many limits and issues with the Tacx and Elite mid’s to recommend any of them.
The S is fine, but has a high power floor, which means you need to shift more than on another trainer. Apart from that it’s quiet and reliable (at least for me so far).
Accuracy doesn’t really matter if you’re using your bike that has a power meter. You will be using power match with your bike power meter wouldn’t you?
I don’t plan on it. I didn’t like using it when I tried it out on a friend’s trainer. Plus I might throw on my commuter bike without a power meter on there.
What issue did you have? Using power match means you are comparing the same power outdoors and indoors. If you use different power sources outside and inside the number wont mean the same thing between the two devices.
I have tracked it a few times and my trainer and my meter don’t match they are close at times but not the same. I have seen a variance of 20-30 watts at certain power outputs.
