it’s already 2.5 years old. Bu there has not been much new stuff, so should give a good overview.
If you want to use SPD cleats the options are Assioma+hack, the mightily expensive SRM pedals or any spider or crank based powermeter.
I use Garmin Vector. Byt my advice is to look for a used power crank. Less expensive and does the job.
The reason I bought Garmin was because I use a spin bike, so can’t change the cranks.
Thanks to all of you. Maybe i was being naive but actually the costs seem to be way too much for data which is somehow interesting for me, but not obligatory to have.
So for now I will leave it at that, but I am sure some other will find help through the input given here by all of you! Thx
Depending on your opinion on costs. But I found mine on the Stages site as a blemished unit. I don’t know what the blemish was, but it was I think $200 (couple years ago, can’t remember for sure).
On the cheaper side there are also the two Chinese spider based ones: Sigeyi and XCadey. I think they are both 300$. And from what I hear they work just fine. (you may have to change cranksets, to fit them)
I also see the FSA Powerbox on sale for 500€ pretty much all the time. It’s a FSA crankset with a rebranded power2max spider based powermeter. So reselling the existing crankset could bring down the net price.
It’s all still quite expensive, but a lot cheaper than many other options.
