*Bontrager Aeolus 7 TLR: 70 deep, 27 wide at brake track. 9 spokes per side.
*Zipp 808, unsure year but is dimpled: 80 deep, 25 wide at brake track. 8 spokes per side.
I’ll be running Vittoria Corsa Speed tires, 25’s, with latex tubes. Course is flat as a pancake. Mild winds 4-6 mph.
Front/rear/pair? If you have a pair of both, I’d go Bontrager front, Zipp rear because the wider rim (Bontrager) will work better with those tyres - measured tyre width should ~95% of the rim width for optimal performance at increasing yaw angles, which is more crucial at the front. If you have a disc for the rear then use the Bonty front.
But in reality I doubt there’s much in it. As Power13 said, pick the one you like, or the one that “feels faster” and smash it.
