Hi folks,
I’ve recently purchased a used left arm xt m8000 power meter (4iiii) for my new Vitus Rapide fs crx which has xt m8100 chainset.
I assumed the crank would fit the same as the oem crank. This is where I’ve gone wrong! The newer m8100 crank is much slimmer at the bb.
The gap between the spindle and the end on the m8000 pm crank is so big the ‘arm fixing bolt’ wont reach the thread on the spindle.
Now I’ve tried using a much longer road ‘arm fixing bolt’ and the crank has been tightened up just fine. The safety tab even fits in the guide hole.
My question is, is this safe to ride or will this less than perfect fitting cause premature wear or even damage to the cranks?
Any advice or insight would be appreciated. Please help!
As you can see fr
