Just a little confused. I have been trying to build my base and have been trying to stay in zone 2 on my rides. I am 51 and have set a maff zone 2 heart rate of 129.
I did an outdoor ride with a buddy this past weekend (proper social distancing in effect) and managed to stay in HR zone 2 for most of the ride. This is from my 4iiii’s left side meter.
As you can see heart rate was pretty good and I was satisfied and then I looked at my power and it was all over the place. Should I be trying to stay in zone 2 power the whole time?
I am approaching a ramp test next week so all my indoor rides this week are zone 2. Here is from an indoor ride.
So I have been concentrating on heart rate but I am thinking I need to have both my heart rate and my power in zone 2 to be really working on zone 2 base? Is this correct? This is the first year I am training outdoors with a power meter.
I wonder if something is wrong with the calculations. If you truly rode at MAF heart rate then how could you possibly accumulate 42 minutes in Z4 (threshold), 12 minutes in Z5, and 4 minutes in Z6?
Heart rate control is normally what I would target for a long Z2 ride, not stepping outside the endurance zone. Terrain can sometimes dictate your power too much. Avg and NP can be a good insight to how you were riding over 3/4 hours, but I wouldn’t be staring at 3second avg power for endurance rides.
After all it is the heart and blood you are trying to train which reaps the most benefits. There is no point doing 200w endurance if you are at Tempo HR.
You sound surprised that the power readings are “all over the place” when riding outside. That is what happens if you don’t keep an eye on your power readings when outside, especially on a hilly course but also when riding with others.
I set a target HR for the ride and if my heart rate drift a little upwards I just ease off the pressure on the pedals ever so slightly. If HR is a little low I just put some more pressure on. In the end there might still be some work done in z4-z6 but not much and certainly not for more than a couple of seconds so it doesn’t influence HR. I usually end up with the majority of the work in z2 but also a substantial amount in z3.
It takes some focused work to keep the power steady so keep one eye on your power readings and one on your HR and get a feel for how much pressure you need to apply to reach your target HR. It might be a good thing to practice on a solo ride; it is difficult to get a steady power when riding with others.
For the last seven years I’ve ridden the endurance days by feel and breathing. Power will go into zone 3 or 4 for some short hills, but HR stays fairly flat for most of the ride, and for a 2.5-3hr ride decoupling will be under 2-3%.
Isn’t most of the improvement in exercise performance with training due to changes in the muscles themselves?
And why would slowing down to reduce your heart rate result in a greater training effect on the cardiovascular system - just because you might be able to go longer, you mean?
My guess is that your ride was rather hilly or had a lot of stop-and-go or coasting. Heart lags behind power by quite a bit, so it would have stayed in zone 2 while your actual effort was all over the map.
Assuming good hydration/fueling/temperatures your HR will increase as Type 1 slow-twitch muscle fibers get tired and more Type 2A fast-twitch get recruited. That increased HR lets us know that the training is sending a signal to the body to adapt and:
increase mitochondria (more power generators)
increase use of fat as fuel source
increase fatigue resistance
increase aerobic function of type 2A fibers
In other words, increased HR is a sign that we’ve started to ride long enough in zone 2 to begin sending adaptation signals to the body. It’s a good thing, embrace it and ride long.
I find it very hard to stay in zone 2 power wise. I think I will just ride for mainly enjoyment and fun outside and will keep to my indoor workouts for training. Any riding outside structured or not will be a bonus.
What’s wrong with his May 10th ride? It looks like a solid level 2 effort to me. The IF of 0.79 is right in the middle of the expected range of 0.75-0.85.
Why would you always try to keep your power in level 2? It seems that would require riding really slow up hills, then bombing down them at a moderately high effort. Nobody I know actually rides that way¡
Ok so some have broken down your rides, pointed to all kinds of technical reasons why your HR and Power Zones are not matching up perfectly…
You’ve been heading out to ride 3-4hr endurance rides. This is great. You’ve been focused on keeping it easy with the occasional effort because they’re fun. More great.
How do you feel?
(For what it’s worth, you’re gaining base training adaptations regardless of the matchymatchy data overlays.)
Does it also mean that once decoupling for certain duration (3h for example) reaches near 0%, it is time to:
reassess FTP,
increase duration or
increase intensity?
While (3) looks like (1) is needed, it is not always the case: did ramp test 2 weeks ago and have done 2x 4hr (IF=0.68) rides weekly since then but HR remains same during first 3 hours. So, hope is that final hour is still driving adaptions for remaining training phase. Or if it does not, add some Z3 intervals into long Z2 ride?
He asked about what he thought was an apparent discrepancy between his heart rate and power data. My point was that there doesn’t seem to be any. Both indicate that he did a level 2 endurance workout.
I only paid attention to hr on the may 10 ride. On the may 16 ride I mainly paid attention to power. Quite frustrating how slow at times and what gears needed to use to stay in zones. Had a tailwind going out and a headwind coming back. Thinking I’ll do all my training/ zone 2 rides on trainer and outside I’ll just do the best I can and have fun while reasonably trying to stay with zones. But prioritize fun over zone?? I’m sure once I get used to it zone 2 will become more fun outside.
