Bmr / daily calories ect
So been trying to understand and focus on my diet to help with my training — curious to what calculator you use to calculate your daily calorie needs disregard activity.
I was using the calculator as below
KJ (4.184) is equivalent to 1 calorie
I use a InBody scanner at a local supplement store often to calculate my BF Ect .
My most recent readings is
BF - 9.9% —- Body Weight - 149lbs — BMR - 7075KJ ( 1691 ) calories
I found a calculator of that states BMR for a very active individual is BMR X 1.725 is daily calorie needs ( 2920c) - however my fitness pal calculates daily calorie needs at 2300 - Well running 2300 calories a day plus additional calories per exercise burn I’m still starving!!!
Currious To how you guys are calculating your daily caloric needs
I’m training around 11-14hrs a week 600-700TSS
I like the calculator below because you can see several calculations all at the same time. According to the info Mifflin St Jeor is the most accurate for resting expenditure.
SailRabbit: BMR, TDEE and BMI Calculator
Usually the activity adjustments are good for background activity and it is better to add exercise calories individually to come up with the total. The activity multiplier differentiates between someone on their feet working construction all day vs a desk job. For both people their cycling calories will be more accurate if you use the info from a PM.
Ultimately it’s all an estimate and the best way to find your maintenance level is keep changing calories slowly until you see weight loss, gain, or maintenance depending on your goals. Unfortunately it’s very hard to be that consistent in diet and activity over several weeks.
Small clarification: BMR (Basal Metabolic Rate) is the calories you burn at complete rest – it doesn’t change based on activity. What you’re probably looking for is TDEE (Total Daily Energy Expenditure), which takes your training and daily activity into account. So you first calculate your BMR, then multiply by an activity factor. Here’s a guide + calculator that explains it clearly: TDEE Guide — Calculate Total Daily Energy Expenditure.
You can adjust this in the settings. You can also link Garmin to your MFP account to add the calories into the calculation.
I generally aim for a rest day number that accounts for my 10k steps (so about 300 calories above BMR), then eat back half of whatever my ride caloric burn is when I’m trying to lose weight. I.e 3 hour ride, burns 2000 calories I try to aim for normal calories+1000.
Typically the on ride nutrition gets me in that ballpark anyway.
