Good afternoon all! Chris here, Loyal TR user and avid TR podcast-listener making my debut on the forum!
I fully expect this to have been a thread before but can anyone point me to a decent nutrition consumption calculator for cycling I.e. something you plug in distance/time/speed/power/body weight/climbing/other relevant metrics and to get a good indication of your nutrition requirements for the specified event
Brendan, I was thinking something very similar to what you wrote, however sports nutrition recs are traditionally 30-60 grams per hour, as 1 grams per minute is supposedly close to the maximum absorbable rate from the human gut.
Now, I know Gebrselassie consumes 80-90 g per hour, but most of my clients start getting GI problems above 60g/hr. WHatâs your experience been? Do you tolerate higher amounts ok?
I appreciate all the replies so far but it makes me realise I worded my query wrong!
Iâm really after trying to calculate the calorific demands of an event - I.e. if I want to ride X at Y speed, will I fuel at 60/hour or need to go higher at 90/h (thus needing to use an alternative strategy/product mix)
Chris, itâs all good advice above. Keep it simple!
I donât know of such a precise calculator, but to try to answer your question we can do some simple calculations to work out how much youâre burning in kJ/hr or kcal/hr based on your power over time.
However, youâll quickly realise that you canât take fuel in at the same rate as you expend itâŚ90g of carbohydrate per hour is ~360kcal per hour (1g of CHO has 17.2kJ or 4.1kcal energy content). Youâre probably expending at least 500kcal/hr. If I average 167W for an hour, thatâs ~600kcal (you can find the calculation here in the TR Blog).
Donât forget youâve got a plenty of fat stored up to use, not to mention ~400g of carbohydrates sitting in your liver and muscles waiting to be used up!
For longer rides, take in what you can stomach! You will need to experiment.
If you want to estimate your calorie consumption, this is how I go about it:
Plug your data (weight, ftp, âŚ) and the GPX in to BestBikeSplit (you donât need a paid subscription)
Run the race simulator, which will give you an estimated time as well as estimated average watts
Estimated Calories (=kcal) = (Avg watts * 3600 sec * estimated hours of your ride in decimal)/1000
Works pretty well for me and turns out to be rather accurate, providing you can interpret the provide time and watts from BestBikeSplit to identify if it matches numbers you could put out IRL.
