I need some help with calories, Kj, and fueling. In the spring when I went through the General Build Blocks I “fueled” like crazy and I gained 5 lbs, and I’d like to avoid that this time around.
On the podcast this week, Alex mentioned that each TR workout as an estimated kJ burn. Amber has talked alot about fueling around the workout and eating reasonably during the rest of the day.
Let me know if I’ve got this figured out… As a benchmark, next week I have Carillion, a 1 hour SS workout with with 623 kJ(cal) estimate, for me at least. While 1 calorie isn’t equal to 1 kJ, after going through our metabolic inefficiency its roughly close.
So if I eat 1 gel before starting (100 cal), and drink 2 bottles of mix with 120 cal each, and finish up with a chocolate milk of 140 cal and a granola bar of 190 then that totals 690 calories, which is pretty close to the calories burned.
Unless you are very skinny you are over fuelling - if it’s less than 2 hours long I just use low cal squash. If it’s 2 hours SS I will use 800mls of energy drink. There are no 1 hour workouts where you need to eat anything. Of course make sure you eat a decent diet…I have a big bowl of porridge in the morning…but unless you train before breakfast - in which case energy drinks are useful you don’t need anything - as you can see from your experience you can still put on weight when training. Of course make sure you eat after your workout but I would find it really difficult to sit on a trainer and eat at the same time. (That said I do take some food if I’m out on a long 4 hour zone 2 ride outside)
For me, gaining 5lbs during build is irrelevant as I’ll shed that weight once I go outside in the summer once my plan is over. I’d rather fuel a little extra than not enough.
Yes, those calories seem to roughly match what you’re burning during the workout. But whether or not you end up losing or gaining weight is a function of your overall calorie balance - so it depends what else you’re eating during the day and what you base metabolic rate is.
What intensity was the workout ? For tempo and above I’ll fuel and re-fuel similar to you (although I’ll substitute the gel for a banana and often don’t touch the 2nd bottle). But for Endurance or recovery sessions I’ll only have half a bottle which I’ll only sip a couple of times.
Thanks for the replies everyone. I’m going to try backing off on the drink mix for 1 hr workouts. Ill keep the same volume of water, just reduce the mix. Im also going to try to keep other meals more reasonable, i.e. no need for a 9pm bowl of oatmeal to get ready for a workout the next afternoon.
I know someone above mentioned appetite, and I definitely think its part of my problem. The deeper I get into consistent training the more I feel like a bottomless pit. I think I may need to add more veg and green stuff instead of an extra scoop of rice or oatmeal!
Someone also asked about what kind of weight was gained. It was some muscle, but also some fat. Thanks for the reminders that its not necessarily a bad thing to gain some weight. Im sure there was definitely some more carbs and water on board to go with a few more watts!
Aim for 60-100g of carb per hour (experiment!!) on the bike for tempo/SS and above and eat well the rest of the time. I know some (I believe including @Nate_Pearson and @Jonathan) will also fuel lower intensity rides (prep for the next hard ride) but I haven’t yet reached that plane of existence. I believe that my decision to take in 90g/hour for all my ‘real workouts’ in 2020 was a big reason (obviously not the only one) for my big performance gains.
Taking in a gel to start is 20g of carbs, plus drink mix is another 60g, which puts me at 80g total. I completely agree that it lowers the RPE. For a 1.5 hour indoor ride I add another gel and another 30g carbs from mix.
I do lighten up on the mix before endurance or recovery rides and usually dont take a gel to start.
Thanks for this charts! Now I’m just trying to sort out the 2 schools of thought… 1hr or less little to no carbs, or the full gas for the workout approach. I had always heard the no carbs for an hour or less in gym class and bro science, but is that for something as focused and difficult as a TR workout? How can I reconcile this with the heavy carbs approach from the podcast guys?
yes. exactly.
When i’m feeling fully loaded i can do the 2.5hr long easy z2 or even 1.5hr sweetspot without any mid-ride snack. it feels wonderful but it will make me craving for food later in the day.
it just when i do back to back hard morning workout (at 5.30 or 6pm), had a decent dinner day before, had enough carb for breakfast (usually ± 30gr carbs from wholemeal bread and 24gr protein from whey protein) i still feel hungry and eventually increasing my RPE. I wonder if the cause is my glycogen level is so low that it’s happen.
any idea about this anyone?
Just my two cents. Even if you keep the same amount of calories, the chocolate milk and granola bar will not satiate you at all. Replace those items with the above-mentioned oatmeal or fruit and veggies, which will help the bottomless-pit feeling (believe me, I know this!) and most likely increase adherence to your diet later the day.
Outside of the working out window, I would highly recommend NOT drinking your calories if you have a high appetite.
It depends on the bigger picture. It might not be necessary to fuel a short SST workout if you take it in isolation. Where does this workout sit amongst the rest of your week/training block?
When I’m doing either a lot of intervals, or a lot of KJs in a week, I tend to play it safe and take on some fuel in-workout even on the easier days. The below week might be a good example…
In terms of the 1x60 SST and Fletcher (90 mins Z2) workouts, in isolation I probably wouldn’t take on any extra fuel on account of the workout itself/KJs, but because the workouts were in between bigger/harder days I fuelled them. There was still a lot of work left to do, and no recovery days in between.
So without knowing what came before/after, it’s hard to recommend how to fuel. In terms of Carillion, I’d say 60g carbs is probably the max you’d need, assuming you’ll be eating as normal.
I do the same - I fuel harder workours appropriately and on easier Z2 days I always get some carbs (around 60g-100g total). I also have a recovery shake after harder workours.
My idea is I have to fuel training block not singular workouts (i do 5-6 workouts/wk).
This guide is specifically for Sufferfest riders, and describes what and when you need to eat on the bike, how much protein and carbs you need and how you can structure a whole week of eating. They references specific Sufferfest workouts so you will need to read between the lines to understand how to apply the ideas to your own diet and training. You can always compare the intensity to whatever your “plan” workouts are. Or just read it and understand that people doing Sufferfest plan (like Jim Gauld) are working very hard, probably harder than most of us.
At the back of the guide are suggested eating plans and there is a list showing carb and protein content of different foods so you can better understand what to eat.
I added a few more web links below to useful guides. The more you read, the better choices you can make. Hope this helps.
