I usually don’t use this stuff, but tried some samples today and it makes sense to use them as my weekends look like they’ll be trying to pack in longer rides (4 to 5hours each hopefully).
Also I’m on a cal deficit so I do worry about messing up a workout day that’s quite tough because I messed feeling up. Usually I’m an eat naturally guy but there is a time and place.
Anyway, I like SIS GO electrolyte. Good price wise in the UK too. Anything else that has more vitamins and electrolytes in there like it. Doesn’t need to be max carb, just some carbs is fine and not silly expensive.
Not wanting to make my own at the moment thanks! Did all that before and it makes sense but want to try OTC stuff for now!
not sure how many electrolites it has but i use this with good results…
You use one bottle per hour…so in your case you can use 4-5
Personally, i only do that if it race time (or extra hot florida long rides)
on longer endurance rides i may do 2 for 62 miles plus 1 gel and one extra of plain water…
This weekend i plan to do 70 and will do 3 bottles and one water… plus the gel
Make your own. That way you can control every aspect of it and get just what you need to fuel your workouts while maintaining your calorie deficit. Below is a link to my formula / recipe.
The gu may seem more expensive, but if you compare energy/carbs and other things you need more product of SIS Go Electro to obtain the same values as the roctane formula. Thats something to consider… Price is not the only factor.
I agree, I use either a mix of Maltodextrin, Fructose and electrolytes (all bought from bulk) or their complete hydration mix. They are very cheap when they offer 40 or 45% discounts.
I use one Nuun sport electrolyte tablet in each bottle, along with Cytosport Cytocarb Powder (maltodextryn) with the appropriate amount of scoops (2,3,4) depending on the fueling requirements of the ride.
Cytocarb has no taste, so you only get the taste of the Nuun sport tablet. Works well and both are available on Amazon.
Tailwind drink mix. I love it. Super easy to handle and plenty of sodium + carbs. Also, Gatorade Endurance mix (what they hand out at Ironman’s) is a good alternative.
I will second the Tailwind (tailwindnutrition.com). I use both Raspberry Buzz (only for morning workouts), the orange, and the naked. I also use the Rebuild after longer/harder intervals.
