As some of you might have seen, we’re working on syncing TrainerRoad workouts to Zwift.
Once we have that ready, you’ll be able to do TR workouts on:
- TrainerRoad
- Zwift
- Garmins
- Wahoos
- Hammerheads
How it works today is that you can create connections to those platforms and then choose what rides you want to do “outside.” Those get pushed to your connected device.
Those rides get this green background
With the way it currently is, you have to plan ahead, and it’s a bit confusing about what’s synced to your device.
So here’s what we’re building for the new way.
Step 1 - Choose your training platforms
Any platform you have connected to will automatically get today’s ride synced to it—no need to plan what is inside or outside.
On the calendar, you’ll be able to verify which rides are synced to your devices.
If you add a workout, you’ll get a little loading state while it syncs, then confirm that it’s hit the training platform you’ve connected.
I think this makes everything a lot easier. You can wake up and decide to do your planned workout on TrainerRoad, Zwift, or outside on your Garmin without having to do anything.
The planned workouts clean themselves up over time, too, so you won’t just end up with a huge library of planned rides that you might not be doing on one device.
Step 2 - Do your workout
Zwift workouts (and all other workouts) will also automatically come back into TrainerRoad, and you’ll still get the blue graphs showing what you did, plus a Zwift map.
We’re currently working on this; it will most likely launch in January.
Let me know if you have any questions/comments!
