I’m curious where the pulse of the forum is on tire width in 2023 for road/tarmac use. The intent would be if you are riding on just road, so not a bike/tire setup where you regularly cover dirt and gravel in addition to pavement.
To keep it consistent, vote in labeled tire width, though if you want to add in the comments what it balloons out to, feel free
I remember listening to Josh Poertner’s podcast about 4 years ago. His comment at the time was that in a few years (I think he was mostly talking about pro’s…but maybe Joe’s as well) most Europeans would be running 28-30mm and Americans would be running 30-32mm.
At the tour this year Jonas was running 28mm Vittoria Corsa Pros (measuring out to 30mm on his Reserve rims) and Tadej ran 28mm GP5000 (measuring out to 31mm on his Enve rims)
I have some evidence of reducing flats (tube tires) when running 32s on the rear wheel. Another local in this area, he does 10-12 double centuries a year, has also seen a reduction in flats by running 32s.
I’m running 25s at the moment, but ideally I’d like to run 28s. The only thing preventing me from running 28s is that the external width of my rims are 26.5 mm (20 mm internal) and everything I’ve read is that there is an aero penalty if the tires are wider than the externals.
Running Corsa NEXT 32 as when I got them last year they were only $55/tire. Great tires overall. However, they raised the price to almost $80 so I think I will try the Pirelli P Zero Race 30s when these wear out.
I actually don’t have a huge problem with flats (I run tubeless) given how much I ride. I just had a full on blowout this summer, and instead of buying replacement 30s I went back to 28s.
I actually think I flat less than my fair share, to be honest. But a gash is a gash … and nothing is going to plug a 1 inch tear lol
I’m running a 28 front and 30 rear on 31 mm outside width wheels. Kept the front aero optimized, then one size up in the back where aero is less of an issue. At least that was the theory, and I’ve been very happy with it.
I also enjoyed the conversation with the guy on 25’s that I beat that was shocked at me running a 30 on my bike.
28 rear 26 front. Vittoria Corsa N.EXT run tubeless on dtswiss dicut 1400. Measure 29.5 in the rear and 27 on front. I’m 170lbs and run them at 60psi. Wayyyyyy more comfortable than a 28/25 gp5000 TL at the same pressure.
fulcrum racing zero db wheelset
25 front, 28 back on 19mm internal rims.
gp5k TL
i scalped all the TL i found at local lbs i have still 3 or four set of TL in both 25 and 28mm that will keep me rolling for the next few years I hope.
